This guide will show you how to remove and replace the fan cooling solution of the laptop if for some reason it has become faulty and needs replacement.
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
Using a plastic opening tool, pull out the back panel from the laptop.
Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
Disconnect the battery connector from the motherboard.
Pull the battery outward and remove it from the rest of the laptop.
Remove the 5.4 mm Phillips #0 screw holding the Wireless Network Card.
Grab the network card and gently pull it out.
Grab the black insulating tape and pull it out.
Using the Phillips #0 screwdriver, remove the (6) six fan screws from the device.
Disconnect the fan from the motherboard.
Unplug the Fan connector from its socket on the motherboard.
Carefully remove the fan from the laptop.
Looks like heat sink and fan are one unit. Advice for regular dust cleaning? How was the condition of the factory thermal paste?
Where can one find this fan?
