Lenovo Edge 15 LCD Screen Replacement
  1. Lenovo Edge 15 LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black plastic or rubber screw caps covering screws, located at the bottom of the screen
  2. Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the (2) M2.5 × 2.5 mm, Black Phillips Nylok coated screws with the Phillips #1 screwdriver, located on either side of the bottom of the screen.
  3. Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry apart plastic cover at the bottom of the screen from plastic hinge cover.
  4. Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the (1) M2.5 x 2.5mm Black Phillips, Nylok coated screw located near the bottom center of the screen with the Phillips #1 screwdriver.
  5. Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide LCD screen around the edges while pulling upwards so that it pops off.
    • Turn the screen over so the touch board is visible, and start working from the back of the screen.
    • Ribbons will be connected in the back of the screen, so be careful not to pull too far that they rip out.
  6. Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the sensor from the sensor board near the bottom left of behind the screen.
  7. Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two ribbons from connectors from the same board from the previous step, near the bottom left of the behind the screen.
    • The ribbon connectors unlatch by pulling up on the very small brown plastic bar near the end of the ribbon.
    • Be careful not to pull on the ribbons before unlatching. This may damage the connector and/or ribbons.
  8. Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape covering a ribbon connector near the bottom of the screen.
    • Disconnect the ribbon by pulling back the small grey latch on the connector and gently pulling the ribbon away.
  9. Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Edge 15 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove LCD screen by gently pulling screen away from the rest of the laptop.
    • Make sure all connections are secure when installing new screen. This eliminates the connection issue if screen is still not working properly after installation.
Gracie Harder
crwdns2935283:009/27/17crwdne2935283:0
311 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S8-G1, Banghart Fall 2017 crwdns2935289:0Cal Poly, Team S8-G1, Banghart Fall 2017crwdne2935289:0
CPSU-BANGHART-F17S8G1
crwdns2947412:05crwdne2947412:0
Does the lcd separate from the digitizer screen or do both need to be replaced if the digitizer is cracked?
Sylvia Gagne - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Typically one can separate the LCD from the glass, but it is a difficult and painful process, and it almost always cracks the LCD. If the cost is not prohibitively expensive, I would just replace them together as one unit.
Allan Wilson - crwdns2950251:0crwdne2950251:0
I need that exact bottom frame strip piece replaced that they are showing in the first picture. Does anyone know where I can order one?
Josselyn Santiago - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
looking to replace the whole screen, if possible even the hinge.
nasty bent screen I have for over 2+ years and I want to change that. Any advice welcomed.
frame is bent, Glass is broken in corner, touch screen gone.
Wouldnt care to install digitizer back but if I can see how to install screen components that be good.
Carry on.
Simarpreet Singh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
que tal joven talvez usted consiguió la pantalla y en que precio por que también tengo el mismo problema quiero cambiar toda la pantalla.
ToplayVid :v - crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 11,652
