Lenovo Chromebook 300e Daughter Board Replacement
    • Check out other guides for removal of the keyboard for Lenovo N23/N21 Chromebooks.
    • Remove the screws from the bottom of the Chromebook.
    • On a clean surface, fold the Chromebook screen over to the back to remove the keyboard.
    • Using a Jimmy remove the keyboard starting at the top of the keyboard.
    • When the entire keyboard has been popped up lift the keyboard from the end opposite the trackpad and carefully disconnect the trackpad and keyboard ribbon cables.
    • Flip over the keyboard so that the keys side is down and place it to the side of your workspace.
    • Check that the thermal pad is still stuck to either the keyboard or the motherboard.
    • Power off the computer by holding down the power button for a few seconds.
    • Disconnect the battery
    • Remove the ribbon cable connecting the Daughter and Motherboard from the motherboard side first.
    • Remove the ribbon cable from the daughter board.
    • Remove the four screws to release the motherboard.
    • Disconnect the speaker wire from the daughterboard.
    • Remove the daughterboard from the Chromebook.
    • Place the new daughterboard in the chromebook.
    • Plug in the speakers to the daughterboard.
    • Screw the daughterboard into place.
    • Connect the ribbon cable, first to the daughterboard and then to the motherboard.
Nathan King
crwdns2935283:008/11/19crwdne2935283:0
353 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 751
