In this guide you will learn how to replace the motherboard and the speaker assembly. Both the motherboard and speaker are connected.
Remove the back cover by prying it open with the metal spudger tool.
Remove the two screws with a PH000 head screwdriver.
Remove the battery by lifting it up using a plastic spudger.
Disconnect the cable from the connection.
Unscrew the 5 black screws, and the 9 silver screws with a PH000 head screwdriver.
Remove the two black panels and the clear circle piece.
Lift up the motherboard carefully, ensuring that you lift the speaker housing and the motherboard together
Lift the bottom speaker piece up carefully
