Remove SD and SIM card from device
Remove screw with a simple coss screwdriver
Remove cover. Starting from the point where you removed the screw.
Disassemble cover clockwise.
Remove screw with simple screw driver
Remove metal holder as shown in picture
Disassemble battery pack. This might require a bit of pressure as it is glued
Hi my tablet is similar to this
So the problem with my tablet is water went in. It does charge but it refuses to turn in, so I was trying to look for the reset pin hole but I can't find it on the tablet. Do you know how it can be fixed?
