This guide will show how to remove the screen for the Lenovo 100s Chromebook-11IBY. This removal will allow you to replace or upgrade the screen for your laptop.
Ensure your device is turned off and unplugged.
Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
Carefully pry up and underneath both the (left & right) hinges of the screen cover.
Use the opening tool on the inside of the screen plate and again on the sides to gently remove it.
Use the #0 Phillips screwdriver to remove the four 6mm screws from the screen.
Gently remove the screen from the plate and place it on the keyboard.
Gently remove the adhesive tape from the back of the screen.
The screen may now be removed completely from the laptop.
