Lenovo 100s Chromebook-11IBY Motherboard Replacement
  1. Lenovo 100s Chromebook-11IBY Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unlock the keyboard ZIF connector to release the keyboard flex cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Unlock the touchpad ZIF connector to release the touchpad flex cable.
    • Carefully pull both flex cables out of the ZIF connectors.
    • Remove the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery cable by pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the three 6mm screws from the battery.
  7. Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  8. Lenovo 100s Chromebook-11IBY Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo 100s Chromebook-11IBY Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo 100s Chromebook-11IBY Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the black nylon spudger, lift up the grey bar of the ZIF connector attached to the motherboard located in the bottom right corner.
    • Pull out the ribbon cable connecting the motherboard to the daughterboard.
  9. Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to coax the sliding speaker cables toward you, out of the motherboard attachments.
  10. Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of the spudger to pop up the display cable connector from the motherboard.
  11. Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up the coaxial antenna cables from the wifi card with the spudger.
  12. Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo 100s Chromebook-11IBY Motherboard Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your Phillips #0 screwdriver to remove six 3.7mm screws from the motherboard.
    • Use the same Phillips #0 screwdriver to remove one 3.2mm screw from the wireless card.
    • Wiggle the motherboard gently out from the case. It should come out towards you and slightly to the right.
Sarah Westberg
crwdns2935283:003/11/19crwdne2935283:0
32,139 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
crwdns2942667:0crwdne2942667:0 966
