Lennox iComfort 10F81 Thermostat Blank Screen Fix
  1. Lennox iComfort 10F81 Thermostat Blank Screen Fix, Electrolytic Capacitors: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You're here because your early-model iComfort screen is blank! The newer Lennox S30 thermostat is the factory replacement for this iComfort, but it cost $1000-$1500 installed (!), so I decided to have a go at a fix.
    • The failure symptoms for my unit included the screen going blank for increasing periods of time over a few weeks before going blank permanently. I could always still control the iComfort via the Lennox iComfort app.
    • Others have reported an all-white screen, lines or odd colors, and since failing capacitors are a common cause of malfunctioning electronics you may have luck with this fix with those types of issues.
  2. Lennox iComfort 10F81 Thermostat Blank Screen Fix: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • A physically damaged or badly burned-in screen will require a new display panel, around $80 on eBay. I further disassembled my iComfort to get the screen part number. You don't need to do this for just the capacitor repair.
    • Lightly press anywhere on the screen to make sure the screen saver is not active. Is the top of the thermostat slightly warm? Is your heating/cooling still working normally? If so, power is likely present and the iComfort itself may still be operating correctly.
    • Hopefully, you or your installer have previously registered your iComfort with Lennox, and you have the iComfort app installed on your cell phone. If so, can you still access and control your iComfort via your cell phone? Good chance of a fix if so. If not, the screen used to work and now it doesn't, so little to lose...
    • First, turn off the circuit breaker to the indoor unit (also called ventilator, heater, fan). Grasp the iComfort and tilt it downwards to unsnap it from the wall mount. Place the iComfort face-down on a smooth surface.
  3. Lennox iComfort 10F81 Thermostat Blank Screen Fix: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lennox iComfort 10F81 Thermostat Blank Screen Fix: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lennox iComfort 10F81 Thermostat Blank Screen Fix: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the guitar pick or small flat screwdriver, gently pry the bezel rim away from the back plate to free the locking tabs. Take note of the small sensor glued into one corner and start your prying opposite to it. There are 10 tabs, but after you get the first 3 or 4 free the rest are easier. Just don't pry beyond what is needed to clear the tabs!
  4. Lennox iComfort 10F81 Thermostat Blank Screen Fix: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is nothing attached to the back plate so just set it aside. The capacitors may have some glue stuck to their bases. Just pick this off; it was used to hold them in place during assembly and need not be replaced.
  5. Lennox iComfort 10F81 Thermostat Blank Screen Fix: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lennox iComfort 10F81 Thermostat Blank Screen Fix: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Dab some flux onto each of the capacitor terminals; this helps the solder melt and flushes away any oxides. Apply your soldering iron to the capacitor solder tabs; gently pull up on that side as the solder melts and the capacitor should lift up. Repeat for the other side and remove the capacitor.
    • If you just can't get the capacitor free, gently rocking and twisting it will eventually break the leads, and you can then easily de-solder the ends still stuck to the circuit board. Proceed at your own risk!
    • Remove any pieces of leads, and clean up the circuit board solder pads by just running your soldering iron over them. Apply some flux to the pads, and position the new capacitor.
  6. Lennox iComfort 10F81 Thermostat Blank Screen Fix: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • PLEASE observe the proper polarities or else damage will occur; look at the pictures; the three large caps all face the same way; the single small cap faces opposite. The white outlines on the circuit board nicely match the shapes of the capacitors' black plastic bases - note that one side has beveled corners.
    • C283 is a bit of a tight fit on one side; you can move the new capacitor slightly away from the adjacent component to give yourself more soldering room, as long as you can still get solder onto the circuit board pads.
    • Apply your soldering iron and some solder to each capacitor tab, heating for long enough that the flux boils and solder flows onto and between the circuit board pad and capacitor lead. The joint should be shiny. Do the other side, and give the capacitor a gentle wiggle to insure the solder joints are good.
    • Repeat for the remaining capacitors and you're done! They will have a tiny bit of play when you nudge them. Optionally, you can remove any excess flux using alcohol wipes or isopropyl alcohol and Q-tips. Look for any stray balls or pieces of solder and remove those.
  7. Lennox iComfort 10F81 Thermostat Blank Screen Fix: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Optional: I used an old doorbell transformer to supply 24VAC to the 'R' and 'C' terminals of the iComfort; it works fine without being connected to the wall plate. I tested it in this state for a week before re-installing it.
    • Replace the back cover plate by carefully snapping the tabs back into place. Hook the bottom of the iComfort onto the small tabs on the wall plate, and swing the top of the iComfort back into the wall plate until it snaps into place. Turn the interior unit circuit breaker back on.
    • It may take a minute or two for the iComfort screen to illuminate even if the repair was successful. I would leave it on overnight before giving up.
    • If successful, the iComfort screen will be on and may show some error warnings. 'X' out of those and the screen should revert to its normal appearance showing temperature, etc. Now, IMPORTANT, SET THE DATE & TIME by pressing on the clock display at lower left. Getting within a few minutes is OK.
    • The iComfort WILL NOT re-establish its WiFi link to the Lennox iComfort server unless the time/date is pretty close. This is not mentioned in the user manual! This step is required if you use the iComfort app, and/or you want your local weather to appear on the display.
  8. Lennox iComfort 10F81 Thermostat Blank Screen Fix: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • I pulled some of the pads off while removing the caps, and had to add jumpers, and use the unpopulated cap slot (I checked for proper connectivity)
I recommend going through any custom iComfort settings to verify they survived (mine did, for 8 months), and I also turned down the screen brightness to the lowest setting of 20%.
crwdns2935229:08crwdne2935229:0
TwoWarm
crwdns2935283:012/08/22crwdne2935283:0
589 crwdns2915208:0crwdne2915208:0
crwdns2947412:060crwdne2947412:0
I have an iComfort 10F81 thermostat that still functions, but has the white screen of death, so I cannot change any of the settings. It came with the home (purchased not long ago) so I do not have an app connected to allow me to make any changes. I was really happy to find this webpage and order the parts. I've had to do a fix like this before on a BMW 3-series HVAC control unit and saved myself $600. Unfortunately when I cracked my unit open and was getting ready to do the repair, I found the PC Board did not match what was shown (mine only had two large caps and a small cap) and the capacitors listed here were not the same as the ones on my unit. Sadly I will have to order the correct capacitors and hope I can find them in stock. For reference, the Part# on my unit is 103445-04. If you plan to attempt this fix, I recommend opening your unit before ordering parts to verify the capacitors you need.
John Buck - crwdns2934203:0crwdne2934203:0
If you're able to reply, I'm not quite sure how to find the right capacitors for my unit. The larger ones read "220 HHB K27" (they are physically about 20% larger than the ones I ordered according to your part numbers); The smaller cap reads "E 723 47 1 0V" or maybe "1 QV" or maybe "10V"
Also, FYI, both of the links in the "What you need" section point to the same capacitor page.
John Buck -
@John Buck - I have the exact some caps in mine; Did you figure it out? I am unable to find anything like these to replace them with!
Craig Smith -
@craigsmith65430 - Using the data sheet that @twowarm posted in reply to my post, I was able to determine that the capacitors (caps) suggested on this site were indeed fungible with those on my unit's PCB. They were different sized, but the voltage codes and capacitance were the same. What's interesting is that my PCB DOES have the pad for the 3rd cap, but doesn't look like one was ever installed. I think I snagged the last caps that were in stock in the above links, so you might need to find a way to source other comparable caps. Again, this link posted by @twowarm was very helpful and could probably serve as a starting point to find caps from another source. I'm not 100% sure, but I don't see why you couldn't use caps w/ the same specs from another MFR
I'm running into issues currently due to my lack of soldering skills, but if I get everything swapped out, I'll probably post a youtube video on the fix. @twowarm are you ok with me posting a vid and giving you a shout out, if I'm successful? I will include a link to this page as well.
John Buck -
Sadly this fix failed to work for me. Difficult to say if it was due to something else being wrong, or if it was simply my terrible soldering job! I had a terrible time probably because my soldering iron was not getting hot enough. One of the pads came off of the circuit board, so that was fun. I got all three caps soldered back on, but the white screen persisted. Looks like rewiring the HVAC for a standard thermostat is my next stop :(
John Buck -
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 122
crwdns2936753:030crwdne2936753:0 663
crwdns2942667:0crwdne2942667:0 34,516
