Leica Z2X Lens Motor Replacement
  1. Leica Z2X Lens Motor Replacement, Remove the Bottom Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
    • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
  2. Leica Z2X Lens Motor Replacement, Open the Back Door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the back door on the camera by pushing down on the door latch.
  3. Leica Z2X Lens Motor Replacement, Remove the Bottom Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
  4. Leica Z2X Lens Motor Replacement, Lens Motor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Having opened the camera and removed the bottom plate, unscrew the five screws marked in the picture.
    • The screw marked in blue is a tiny bit harder to find because it's in a crevice. Don't miss it!
  5. Leica Z2X Lens Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply pressure until the piece you unscrewed in the last step pops off.
  6. Leica Z2X Lens Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four screws on the back of this piece to the lower-left corner of the lens.
  7. Leica Z2X Lens Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Removing the lens motor cover, you should be left with these four pieces.
  8. Leica Z2X Lens Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Located underneath these four pieces is the lens motor.
  9. Leica Z2X Lens Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that you've removed the bottom plate, you can pull apart the front and back covers.
    • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
  10. Leica Z2X Lens Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, the back cover.
    • Apply pressure to remove the back plate.
    • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
    • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
  11. Leica Z2X Lens Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You should now have removed the front and back plates.
  12. Leica Z2X Lens Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws holding on the front panel surrounding the lens.
  13. Leica Z2X Lens Motor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three gears under the panel you removed in the last step and the lens motor should be able to be removed.
Zachary
crwdns2935283:004/12/11crwdne2935283:0
46 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-19, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 18-19, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S18G19
crwdns2935297:013crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,943
