Leica Z2X Lens Cover Replacement
    1. Leica Z2X Lens Cover Replacement, Remove the Bottom Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
      • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
    2. Leica Z2X Lens Cover Replacement, Open the Back Door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Open the back door on the camera by pushing down on the door latch.
    3. Leica Z2X Lens Cover Replacement, Remove the Bottom Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Apply pressure to the bottom plate and it will pop off.
      • From here, you can replace the bottom plate, or continue on to further steps.
    1. Leica Z2X Lens Cover Replacement, Lens Motor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five screws marked in the picture.
    2. Leica Z2X Lens Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Apply pressure until the piece you unscrewed in the last step pops off.
    3. Leica Z2X Lens Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the four screws on the back of this piece to the lower-left corner of the lens.
    4. Leica Z2X Lens Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Removing the lens motor cover, you should be left with these four pieces.
    5. Leica Z2X Lens Cover Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Located underneath these four pieces is the lens motor.
    6. Leica Z2X Lens Cover Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Now that you've removed the bottom plate, you can pull apart the front and back covers.
      • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
    7. Leica Z2X Lens Cover Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Next, the back cover.
      • Apply pressure to remove the back plate.
      • Potential for device damage: Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
      • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
    8. Leica Z2X Lens Cover Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • You should now have removed the front and back plates.
    9. Leica Z2X Lens Cover Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four screws holding on the front panel surrounding the lens.
    10. Leica Z2X Lens Cover Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three gears under the panel you removed in the last step and the lens motor should be able to be removed.
    1. Leica Z2X Lens Cover Replacement, Lens Cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Now that the lens motor has been removed, you can apply pressure to the back of the lens and push it out.
      • From here, locate the three screws near the front of the lens.
      • Unscrew these three screws.
    2. Leica Z2X Lens Cover Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • From here, you can pull out the small disk containing the lens cover.
      • Unscrew the four screws on the back and pull the two pieces of the disk apart.
    3. Leica Z2X Lens Cover Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • From here, you can replace any broken parts in the lens cover.
Kenny
crwdns2935283:004/10/11crwdne2935283:0
57 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-19, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 18-19, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S18G19
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 133
crwdns2942667:0crwdne2942667:0 4,069
