Leica Z2X Flash Diffuser Replacement
crwdns2869540:0crwdne2869540:0: 4.3천
4
25
110
4,261
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: 20 - 45 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937595:0crwdne2937595:0
crwdns2862627:0crwdne2862627:0
crwdns2862628:0crwdne2862628:0
Use this guide to replace the Flash Diffuser.
    1. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
      • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
    2. Leica Z2X Flash Diffuser Replacement, Open the Back Door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Open the back door on the camera by pushing down on the door latch.
    3. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Apply pressure to the bottom plate and it will pop off.
      • From here, you can replace the bottom plate, or continue on to further steps.
    1. Leica Z2X Flash Diffuser Replacement, Flash Diffuser: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Now that you've removed the bottom plate, you can pull apart the front and back covers.
      • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
    2. Leica Z2X Flash Diffuser Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Next, the back cover.
      • Apply pressure to remove the back plate.
      • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
      • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
    3. Leica Z2X Flash Diffuser Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • You should now have removed the front and back plates.
    4. Leica Z2X Flash Diffuser Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Removing the flash diffuser should be simple from here.
      • Simply take the front cover and apply pressure to the front of the flash diffuser and it should pop right out.
Kenny
crwdns2935283:004/10/11crwdne2935283:0
57 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-19, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 18-19, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S18G19
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 110
crwdns2959996:0crwdne2959996:0 4,261
