Lego Dimensions Starter Pack USB Cable Replacement
  1. Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
  2. Lego Dimensions Starter Pack USB Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
  3. Lego Dimensions Starter Pack USB Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the top cover off.
  4. Lego Dimensions Starter Pack USB Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the circular illumination stand and remove it from the toy pad.
  5. Lego Dimensions Starter Pack USB Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the white L-shaped pieces and remove them from the toy pad.
  6. Lego Dimensions Starter Pack USB Cable Replacement, USB Cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
    • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
    • Remove the USB cable from the toy pad.
crwdns2935229:05crwdne2935229:0
Alyssa Lach
crwdns2935283:011/06/17crwdne2935283:0
563 crwdns2915208:0crwdne2915208:0
IUPUI, Team S5-G2, Baechle Fall 2017 crwdns2935289:0IUPUI, Team S5-G2, Baechle Fall 2017crwdne2935289:0
IUPUI-BAECHLE-F17S5G2
Where do you buy the USB cable from?
jaimea371 - crwdns2934203:0crwdne2934203:0
I bought a lego dimensions pad (tested and working cable) then opened it, grabbed the usb cable and, replaced the broken cable on my old lego dimensions pad. It worked. Maybe give a try.
tictac25 -
mguzmanv - crwdns2934203:0crwdne2934203:0
I used the usb cable from a different pad, and, replaced the broken cable on my lego dimensions pad (xbox one). It worked. Maybe give a try.
tictac25 -
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 6,617
