Robotic vacuum batteries generally last 2-3 years, depending on usage. Over time, you may notice that the battery holds less charge, requires more frequent recharging, or a decrease in cleaning performance. Use this guide to help replace your battery and restore your Lefant M210 robot vacuum to like-new performance.
Before you begin this repair, turn off the vacuum.
Flip the Lefant M210 over to have a clear view of the brushes.
Place the blue tool under the circular part of the brush in the center
Push down the other end of the tool to pop out the brush component
Use a Phillips screwdriver to remove four screws near each wheel.
Remove the plastic cover next to each wheel.
Grip both sides of the wheel and pull upwards.
Hold the wheel up and detach the connector to release it from the device.
Open the dustbin compartment.
With your hands, gently pull the dustbin to remove it from its compartment.
With your hands, pull off the filter compartment from the dustbin.
Pull off the filter from the filter compartment.
Use a Phillips #1 screwdriver to remove the six screws around the bottom edge of the device.
Rotate the vacuum so that the Lefant logo is facing you.
Carefully lift the white cover of the vacuum, opening it like a laptop, from front to back.
Rest the open cover something stable, like a wall.
Use a Phillips #1 screwdriver to remove the three screws securing the motherboard to the device.
Push the two retaining clips away from the battery while pulling the battery up from the tabs attached to it to free it.
Retaining clips
Battery tabs
When the battery is free from it's housing, lift it out completely using its pull tabs.
Locate the battery connection wire and carefully pull apart the connection.
Pinch the motherboard's wire connector and pull the connection apart.
Great guide! Any knowledge on how or why mine beeps twice even when it is on the ground?
