Led Lenser P2 BM Button Disassembly
  1. Led Lenser  P2 BM  Button Disassembly, Unscrew rear cap from the main housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is exactly how you would do it if you were changing the battery.
  2. Led Lenser  P2 BM  Button Disassembly, Remove O-ring: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small O-Ring, I used a plastic toothpick.
  3. Led Lenser  P2 BM  Button Disassembly, Screw apart cap: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Led Lenser  P2 BM  Button Disassembly, Screw apart cap: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now we will unscrew the aluminum cap from the plastic lower part. I used a pair of pliers to carefully hold the plastic part while unscrewing the aluminum part with my finger. Left-hand thread.
  4. Led Lenser  P2 BM  Button Disassembly, Split housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The plastic housing holds the actual button assembly and is made from two halves, These can carefully be pried apart wit a knife.
  5. Led Lenser  P2 BM  Button Disassembly, Open button assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Led Lenser  P2 BM  Button Disassembly, Open button assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Button assembly mark in red circle. This is held together by 4 plastic "rivets" on the connector side, marked in green. Cafully cut these flush like in the picture.
  6. Led Lenser  P2 BM  Button Disassembly, Separate the button. Clean and ispect: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Led Lenser  P2 BM  Button Disassembly, Separate the button. Clean and ispect: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You can then pry of the "lid" like in the third picture.
    • Carefully remove the inner springs and plungers. In the picture one small plunger is still in the top of the button.
    • In my case the problem was a tiny plastic "!shaving" inside the button blocking it from making a connection, Market with yellow arrow.
  7. Led Lenser  P2 BM  Button Disassembly, Reassemble: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Is reversed of disassembly but you don't need to glue the button together (the small plastic "rivets" are now broken) because the two part plastic housing will keep it together when assembled.
    • I have used it like this for years until the same problem happen again, so added some new images while fixing it again.
Hans
crwdns2935283:004/25/16crwdne2935283:0
400 crwdns2915208:0crwdne2915208:0
Dear Hans.
I have used the same P3 LED for many years in bad switch condition.
Today I cleared this problem with your solution.
Very thank you & I'm appreciate to you.
DS2DDE
from Seoul, Korea.
김도욱 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 3,274
