Leapfrog My Own Leaptop Speaker Replacement Guide
  1. Leapfrog My Own Leaptop Speaker Replacement Guide, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Speaker Replacement Guide: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Speaker Replacement Guide: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Leapfrog My Own Leaptop Speaker Replacement Guide: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Speaker Replacement Guide, Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Speaker Replacement Guide: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Speaker Replacement Guide: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Leapfrog My Own Leaptop Speaker Replacement Guide: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 7.5 mm screws to the left and right of the speaker with a PH1 phillips head screwdriver.
    • Remove the cover and place to the side.
  7. Leapfrog My Own Leaptop Speaker Replacement Guide: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Leapfrog My Own Leaptop Speaker Replacement Guide: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the cover is removed, gently lift up the speaker making sure not to rip or break the wires.
    • If you are disassembling the device to clean the speaker, clean it at this point with a soft, lightly dampened cloth.
    • Gently turn the speaker over and carefully desolder the white and yellow wires from the speaker.
    What do you do when you "disolder" the cables?
    Iris T - crwdns2934203:0crwdne2934203:0
    What do you do if the yellow wire is already broken off the silver part? How do you reapply it?
    Erika Mata - crwdns2934203:0crwdne2934203:0
    Our white wire is halfway off, so I’m wondering if it can be soldered back on
    Carissa holland -
    Speaker measurements (measured with digital caliper):
    0.25 W / 16 ohm / 35.5mm diameter (anything smaller will work, but will rattle around)
    Yellow wire to leftmost solder point, White wire to rightmost solder point.
    Embossed on speaker: 16ohm / M-0.25W / CPC
    me262 - crwdns2934203:0crwdne2934203:0
    Also remember to back out the screws to where you hear a “click” before screwing them in (this finds the previous threads so you won’t make new threads in the screwposts).
Any issues that cannot be resolved with any portion of this wiki please contact Leapfrog Customer Serivce
Jonathan Fitzer
crwdns2935283:002/10/16crwdne2935283:0
584 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-6, Lacy Spring 2016 crwdns2935289:0USF Tampa, Team 14-6, Lacy Spring 2016crwdne2935289:0
USFT-LACY-S16S14G6
crwdns2947412:05crwdne2947412:0
Thanks for this very useful instruction. Where can I buy a replacement speaker?
-Don
Don La - crwdns2934203:0crwdne2934203:0
I agree, but I also second the question...where can I buy a replacement speaker?
Jimmy Liang - crwdns2934203:0crwdne2934203:0
Where could I purchase a replacement speaker?
Zuzi - crwdns2934203:0crwdne2934203:0
Where could I buy the replacement speaker in Malaysia?
stanley.met - crwdns2934203:0crwdne2934203:0
Where can I buy replacement speaker in Malaysia? Appreciate yr reply
ribenabona - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,150
