This guide will show the user how to access and clean or replace the speaker in the Leapfrog My Own Leaptop.
Flip over device so that back portion of the device is facing you.
Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
Remove the three AA batteries.
Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
Unscrew the two 7.5 mm screws to the left and right of the speaker with a PH1 phillips head screwdriver.
Remove the cover and place to the side.
Once the cover is removed, gently lift up the speaker making sure not to rip or break the wires.
Gently turn the speaker over and carefully desolder the white and yellow wires from the speaker.
Any issues that cannot be resolved with any portion of this wiki please contact Leapfrog Customer Serivce
crwdns2947412:05crwdne2947412:0
Thanks for this very useful instruction. Where can I buy a replacement speaker?
-Don
I agree, but I also second the question...where can I buy a replacement speaker?
Where could I purchase a replacement speaker?
Where could I buy the replacement speaker in Malaysia?
Where can I buy replacement speaker in Malaysia? Appreciate yr reply
