This guide is designed to instruct users on how properly replace dead or low batteries in the device. Tools will be necessary as well as new AA batteries.
Flip over device so that back portion of the device is facing you.
Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
Remove the three AA batteries.
Hi Jonathan! Your article is very helpful. But I have a big question now. I have opened the leaptop and see that membrane should be replaced. But where can I buy the membrane separately? Please help!
Alina Timchenko - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
