During this guide you will take apart the leapfrog and replace the board containing the speaker, audio jack, and directional pad.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
Unplug the battery from the motherboard with your hands.
Pry the battery gently off of the plastic platform with an opening tool.
Disconnect the audio cord from the motherboard using a plastic opening tool.
Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
Remove the board and speaker from the device.
Where can I purchase a replacement audio board /speaker for the LeapPad3?
