This guide will require removing the case as well as unplugging several components and removing the mother board as a whole.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
Unplug the battery from the motherboard with your hands.
Pry the battery gently off of the plastic platform with an opening tool.
Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
