If your display assembly is scratched or not working properly this is the appropriate guide to get the issue resolved. It is a rather lengthy, however, it is complete and few tools are needed.
crwdns2936621:0crwdne2936621:0
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
Unplug the battery from the motherboard with your hands.
Pry the battery gently off of the plastic platform with an opening tool.
Disconnect the audio cord from the motherboard using a plastic opening tool.
Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
Remove the board and speaker from the device.
Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
Unscrew the eight 6.5mm Phillips #0 screws from the plastic casing.
Remove the covering with your hands to allow full view of the display assembly.
Remove the display assembly from the black rubber sleeve carefully.
crwdns2935229:05crwdne2935229:0
Everything worked ok but unit now will not go to home page. after I replaced the display. They tell you necessary tools but never tell you where or how to use the wrist grounding strap.
Bonjour, j’ai bien réussi à accéder à l’écran,
Ma question:
Oû peut-on se procurer un écran neuf SVP?
Pouvez vous m'indiquer où trouver un écran de remplacement ?
Merci d'avance
OK, Visiblement ce tuto ne sert plus à rien car il est Impossible de trouver le display de remplacement!!
