Le Pavé Parisien V1: Replacing the loudspeaker
  1. Le Pavé Parisien V1: Replacing the loudspeaker, Remove the grill: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Le Pavé Parisien V1: Replacing the loudspeaker, Remove the grill: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speaker protective grill by first lifting one corner.
  2. Le Pavé Parisien V1: Replacing the loudspeaker, Unscrew the loudspeaker: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Le Pavé Parisien V1: Replacing the loudspeaker, Unscrew the loudspeaker: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 speaker retaining screws using an M4 allen wrench.
  3. Le Pavé Parisien V1: Replacing the loudspeaker, Disconnecting the loudspeaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Le Pavé Parisien V1: Replacing the loudspeaker, Disconnecting the loudspeaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the speaker out of the concrete shell in order to access the connections.
    • To disconnect the speker, pull each of the cables, gripping the connector and easing it from side to side.
    • You only have to connect the replacement speaker and follow the instructions in reverse in order to reassemble your Pavé Parisien.
  4. Le Pavé Parisien V1: Replacing the loudspeaker, Replacing the speaker in the shell: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Le Pavé Parisien V1: Replacing the loudspeaker, Replacing the speaker in the shell: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect the speaker as in step 3. Take care to ensure the connectors are on the side where there is a notch in the concrete.
  5. Le Pavé Parisien V1: Replacing the loudspeaker, Finish: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You only have to replace the screws and the protective grill and your Pavé Parisien is reassembled!
Follow these instruction in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934883:0Philip Le Richecrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Le Pavé Parisien
crwdns2935283:004/03/19crwdne2935283:0
529 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 97
