Lawn Mower 460BSP500E-3 Carburetor Replacement
  1. Lawn Mower 460BSP500E-3 Carburetor Replacement, Required Tools: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Required Tools: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Required Tools: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Socket wrench, and 5/16 inch and 9/32 inch sockets
    • Pliers
    • Container for gasoline
    • If you don't have US Standard (inch) sockets, you can substitute a 8 mm metric for the 5/16" socket and a 7 mm metric for the 9/32".
  2. Lawn Mower 460BSP500E-3 Carburetor Replacement, Disassemble the Pull Starter: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Disassemble the Pull Starter: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Disassemble the Pull Starter: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the pull starter allows for much easier access to replace the carburetor.
    • Unscrew the 3 mounting screws with a 5/16 inch wrench.
  3. Lawn Mower 460BSP500E-3 Carburetor Replacement, Remove the Pull Starter: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Remove the Pull Starter: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the pull starter once the screws have been removed.
  4. Lawn Mower 460BSP500E-3 Carburetor Replacement, Remove the Air Filter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Remove the Air Filter: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Remove the Air Filter: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take off the air filter cover.
    • Remove the filter element to access the carburetor mounting screws.
  5. Lawn Mower 460BSP500E-3 Carburetor Replacement, Remove the Air Filter Housing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Remove the Air Filter Housing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Remove the Air Filter Housing: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2 screws marked "A" on the photo with a 5/16 inch socket.
  6. Lawn Mower 460BSP500E-3 Carburetor Replacement, Carburetor disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Carburetor disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Carburetor disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2 screws marked "B" on the photo with the 9/32 inch socket wrench.
  7. Lawn Mower 460BSP500E-3 Carburetor Replacement, Dismount the Air Filter Housing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Dismount the Air Filter Housing: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Dismount the Air Filter Housing: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the housing by disconnecting the breather hose.
    • Remove the housing.
  8. Lawn Mower 460BSP500E-3 Carburetor Replacement, Remove the Fuel Tank and Carburetor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Remove the Fuel Tank and Carburetor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Remove the Fuel Tank and Carburetor: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the tank up to unhook it.
    • Pull the carburetor towards you.
    • Tilt it downwards to separate the rod from the regulator marked "C" in the photo.
  9. Lawn Mower 460BSP500E-3 Carburetor Replacement, Detach the Fuel Tank: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Detach the Fuel Tank: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Detach the Fuel Tank: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the pliers, slide off the clamp to disengage the fuel hose.
  10. Lawn Mower 460BSP500E-3 Carburetor Replacement, Empty the Fuel Tank: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Drain the gasoline into an appropriate container.
  11. Lawn Mower 460BSP500E-3 Carburetor Replacement, Replace the Carburetor: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Replace the Carburetor: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Replace the Carburetor: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reconnect the hose from the tank to the carburetor.
    • Reposition the spring clamp with the pliers.
  12. Lawn Mower 460BSP500E-3 Carburetor Replacement, Mount the Fuel Tank / Carburetor Assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Mount the Fuel Tank / Carburetor Assembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Mount the Fuel Tank / Carburetor Assembly: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Holding the carburetor on its side, insert the throttle rod onto the throttle plate control.
    • Rotate the assembly up 90° and position the carburetor on the intake pipe.
    • Slide the fuel tank into its mounting notches.
  13. Lawn Mower 460BSP500E-3 Carburetor Replacement, Reassemble the Carburetor and Air Filter Housing: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Reassemble the Carburetor and Air Filter Housing: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Refit the breather hose.
    • Reposition the air filter housing, taking care to align the screw holes with the support bracket.
  14. Lawn Mower 460BSP500E-3 Carburetor Replacement, Replace the Air Filter Housing Screws: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Replace the Air Filter Housing Screws: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Replace the Air Filter Housing Screws: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tighten the 2 screws marked "A" on the photo with a 5/16 inch socket.
  15. Lawn Mower 460BSP500E-3 Carburetor Replacement, Replace the Carburetor Screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Replace the Carburetor Screws: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Replace the Carburetor Screws: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tighten the 2 screws marked "B" on the photo with a 9/32 inch socket.
  16. Lawn Mower 460BSP500E-3 Carburetor Replacement, Install the Air Filter Element and Cover: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Install the Air Filter Element and Cover: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Install the Air Filter Element and Cover: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Refit the filter element and the cover, taking care to align the notches in the cover.
  17. Lawn Mower 460BSP500E-3 Carburetor Replacement, Reinstall the Pull Starter: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Reinstall the Pull Starter: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lawn Mower 460BSP500E-3 Carburetor Replacement, Reinstall the Pull Starter: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reposition the pull starter and secure it with the three screws using the 5/16 inch socket.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0635crwdne2935297:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 2,765
