LaunchPad CleanUp
    • Locate the Terminal and open
    • Type the following command, this will create a backup folder on your desktop for your launchpad app.
    • mkdir ~/Desktop/DB_Backup
    • Type the following command to copy the database. This will place it in the back folder that was created in the second step.
    • cp ~/Library/Application\ Support/Dock/*.db ~/Desktop/DB_Backup/
    • Type the next command, this will put the LaunchPad back to its original setup and will take all programs out of folders.
    • sqlite3 ~/Library/Application\ Support/Dock/*.db 'DELETE from apps;' \ ' DELETE from groups WHERE title<>""; DELETE from items WHERE rowid>2;' \ && killall Dock
    • However, it should be noted that the folders will not disappear. To get rid of them, simply load at least one app into Launchpad, then drag the app into & out of the folder. It will 'evaporate' when it's empty.
    • If you want to do a full reset of the LaunchPad, I will create another guide for those steps.
Elle Snickens
crwdns2935283:003/22/14crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
this command gives a syntax error in High Sierra.
Wade Smith - crwdns2934203:0crwdne2934203:0
It says “no such table” when I copy the command in terminal, I’m using Mac OS high sierra 10.13.6
Michael Z - crwdns2934203:0crwdne2934203:0
It is a very simple method.<a href="https://technumus.com/how-to-remove-icon...>HOW TO REMOVE ICONS FROM DESKTOP MAC</a>
Johan william - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,921
