Laser X 88016 LED Lights Repair
  1. Laser X 88016 LED Lights Repair, Laser X 88016 LED Lights Repair: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Laser X 88016 LED Lights Repair, Laser X 88016 LED Lights Repair: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the one 9.6 mm screw from the bottom of the laser gun and pull off the battery cover.
    • Phillips #0 will be used for all subsequent screw extractions throughout this guide.
    • Remove the three AAA batteries.
  2. Laser X 88016 LED Lights Repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Laser X 88016 LED Lights Repair: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Laser X 88016 LED Lights Repair: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the six 9.6 mm screws located on the back of the receiver to expose the circuit board.
  3. Laser X 88016 LED Lights Repair: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Laser X 88016 LED Lights Repair: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 9.6mm screw fixing the circuit board to the receivers front cover using the Phillips #0 screwdriver.
  4. Laser X 88016 LED Lights Repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify the LED wires on the circuit board and determine where the wires have become disconnected or shorted.
  5. Laser X 88016 LED Lights Repair: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Laser X 88016 LED Lights Repair: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Laser X 88016 LED Lights Repair: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The LED wires are labeled TX and TG.
    • Use a helping hand to hold circuit board steady for soldering.
    • Solder the disconnected wire to the circuit board (in this case, the white wire to the node labeled TX.
    • Caution: Never touch the element or tip of the soldering iron. They are very hot (about 400°C) and will burn. Always return the soldering iron to its stand when not in use.
  6. Laser X 88016 LED Lights Repair: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Laser X 88016 LED Lights Repair: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Laser X 88016 LED Lights Repair: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reattach the circuit board to the receiver's front plate.
    • Put the batteries back in the laser gun and test for LED lights functionality.
    • If a specific LED light still does not function, verify the solder is not making a connection with the adjacent nodes.
James Lewis
crwdns2935283:009/15/20crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Hi, Do you know the PN for SW1? that turn on and off the unit?
Thanks
Alon S. - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,992
