Laser Lens Cleaning
  1. Laser Lens Cleaning, Top Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Laser Lens Cleaning, Top Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Laser Lens Cleaning: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Laser Lens Cleaning: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Laser Lens Cleaning, Laser Lens Cleaning: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Laser Lens Cleaning, Laser Lens Cleaning: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the lens on the disc drive.
    • Make sure that there is no dust on or near the player and area you are working on. Dust can get on the lens and scratch it while you are cleaning. It is very important that the lens is not damaged because the lens is used to read the discs.
    • Dip one end of a cotton swab in rubbing alcohol.
    • Lightly dab the swab on the lens. Be very gentle.
    • Let the lens dry before replacing the top plate of the DVD player.
crwdns2935229:015crwdne2935229:0
Nathan Klammer
crwdns2935283:010/06/11crwdne2935283:0
506 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-20, Maness Fall 2011 crwdns2935289:0Cal Poly, Team 21-20, Maness Fall 2011crwdne2935289:0
CPSU-MANESS-F11S21G20
crwdns2947412:05crwdne2947412:0
This item was not appropriate, thank you for trying.
bigd734 - crwdns2934203:0crwdne2934203:0
Works on Samsung's box(home theater), thank you!
CarlBraun - crwdns2934203:0crwdne2934203:0
It worked on my cheap player. This unit is on 24/7. The dust in the house is heavy and smokers so the fix is cheap and I picked up a few things. Thanks
Seeker - crwdns2934203:0crwdne2934203:0
My problem I think is alignment
James Smith - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 132
crwdns2936753:030crwdne2936753:0 608
crwdns2942667:0crwdne2942667:0 56,061
