Large Animal Water Nipple Replacement
  1. Large Animal Water Nipple Replacement, Large Animal Water Nipple: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Empty the container of all water.
  2. Large Animal Water Nipple Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With an adjustable wrench, unscrew the nut on the inside located near the base on the backside of the nipple.
  3. Large Animal Water Nipple Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the mechanism out from the front.
  4. Large Animal Water Nipple Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure there is no damage to the hole that needs to be patched.
    • Cracks or fractures are easily made due to sun damage or forcing the mechanism in or out.
  5. Large Animal Water Nipple Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use Teflon tape to line the threads of the new nipple.
  6. Large Animal Water Nipple Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Large Animal Water Nipple Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the new nipple in the hole with the peg on top.
  7. Large Animal Water Nipple Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fill the container slightly to ensure that there are no leaks. Tighten the washer or pull out to see if a crack has formed while replacing.
    • Tighten the washer to see if that is the source of the leak. If not, pull out to see if a crack has formed while replacing.
    • This is a leak in the seal.
  8. Large Animal Water Nipple Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If there is a leak try placing some more Teflon tape. If this does not fix the issue continue reading this step. If there is no longer a leak, move on.
    • Leaking from cracks are easily filled with caulking if the container is small. This would only be a temporary fix on a larger container. Due to the weight of the water, the barrel or bucket would need to be replaced.
  9. Large Animal Water Nipple Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place and thread the nut on the inside of the container on the backside of the nipple.
  10. Large Animal Water Nipple Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally, place the container in the designated place and fill completely.
Katelyn Root-Nelson
crwdns2935283:004/11/19crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S25-G4, Crane Spring 2019 crwdns2935289:0Eastern Washington University, Team S25-G4, Crane Spring 2019crwdne2935289:0
EWU-CRANE-S19S25G4
crwdns2942667:0crwdne2942667:0 305
