crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0LIFX BR30crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. LIFX BR30 Teardown, Remove the Diffuser: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LIFX BR30 Teardown, Remove the Diffuser: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LIFX BR30 Teardown, Remove the Diffuser: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The diffuser is held onto the bulb's base by four snap-lock plastic tabs, which also have a dab of silicone adhesive on them to prevent the diffuser from rattling.
    • The tabs are just to the right of the small Phillips-head screws you can see in the small space between the diffuser and base.
    • Insert a strong chisel or similar prying tool to bend the plastic tabs. You'll need to bend at least two at once, and then insert something to hold open the one side while you work on the other.
    • After removing the diffuser, remove the rubber white silicone gasket (photos two and three) and set aside.
  2. LIFX BR30 Teardown, Remove PCB Shield: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LIFX BR30 Teardown, Remove PCB Shield: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the diffuser exposes the LED PCB. The edge of the WiFi board can also be seen with the antenna protruding.
    • Note the silicone adhesive on the tabs. You probably don't need to replace this with fresh adhesive, but if you do, make sure it's rated for high temperatures.
    • On the LED PCB, you can see the white and colored LEDs. The PCB is a thermally-conductive aluminum material.
    • Around the edge of the bulb's case there is a plastic retaining ring attached by four Phillips-head screws. It's not necessary to remove this for further disassembly.
    • The LED PCB has a pin header that connects down into the WiFi board. A thermal adhesive pad holds the PCB to the metal bulb case. You can gently pry around the edge of the PCB until the adhesive releases, and the connector separates.
    • On my bulb, the PCB was not fully-seated on the thermal pad, potentially causing heat-related intermittent faults.
  3. LIFX BR30 Teardown, Remove LED PCB: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The gray material that is solidified around the PCB tears away quite easily, but I stopped here as my light still half-works and I didn't want to risk damaging it further. When we procure more courage, I'll return here to discuss how we removed the gray material that coats the board and steel sidewalls of the PCB's cage.
NorthernBigDummy
crwdns2935283:008/25/15crwdne2935283:0
742 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,032
