LG Xenon Motherboard Replacement
crwdns2869540:0crwdne2869540:0: 1,7 тыс.
3
18
76
1 692
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:05crwdne2931287:0
If your LG Xenon GR500 is not turning on from water exposure or drop impact, the issue may be resolved by replacing the motherboard. Handling the motherboard is considered a risky repair that can cause further damage to the device if not operated correctly, so proceed cautiously. This guide will show you how to remove and replace the motherboard carefully.
    1. LG Xenon Motherboard Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the phone so the back side is face up.
    2. LG Xenon Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your thumb to press on the small ridge at the bottom of the phone, then push upward to slide off the back casing.
    1. LG Xenon Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
    1. LG Xenon Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
    2. LG Xenon Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push a spudger or small tool under the inner edge of the back panel and gently pry upward to separate it from the main body.
    3. LG Xenon Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pop off the camera, lock, and volume buttons from the side of the phone using tweezers.
    4. LG Xenon Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the Phillips #00 screwdriver to remove the two 3mm screws, which secure the motherboard.
    5. LG Xenon Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully lift and remove the motherboard from the main body.
      • The connector cable will still be attached to the motherboard. Any damage to the connector cable may permanently disable the phone.
    6. LG Xenon Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully unclip the metal tab to separate the connector cable from the motherboard.
    7. LG Xenon Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the connector cable is detached from the motherboard, you have successfully removed the motherboard from the phone.
Micaela Saqui
crwdns2935283:004/19/12crwdne2935283:0
78 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-41, Regan Spring 2012 crwdns2935289:0Cal Poly, Team 9-41, Regan Spring 2012crwdne2935289:0
CPSU-REGAN-S12S9G41
crwdns2935297:096crwdne2935297:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 76
crwdns2959996:0crwdne2959996:0 1,692
