LG Xenon Microphone Replacement
  1. LG Xenon Microphone Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the phone so the back side is face up.
  2. LG Xenon Microphone Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Microphone Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your thumb to press on the small ridge at the bottom of the phone, then push upward to slide off the back casing.
  3. LG Xenon Microphone Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Microphone Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
  4. LG Xenon Microphone Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Microphone Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
  5. LG Xenon Microphone Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push a spudger or small tool under the inner edge of the back panel and gently pry upward to separate it from the main body.
  6. LG Xenon Microphone Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Microphone Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pop off the camera, lock, and volume buttons from the side of the phone using tweezers.
  7. LG Xenon Microphone Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Microphone Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the two 3mm screws, which secure the motherboard.
  8. LG Xenon Microphone Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Microphone Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift and remove the motherboard from the main body.
    • The connector cable will still be attached to the motherboard. Any damage to the connector cable may permanently disable the phone.
  9. LG Xenon Microphone Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Microphone Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully unclip the metal tab to separate the connector cable from the motherboard.
  10. LG Xenon Microphone Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Microphone Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the connector cable is detached from the motherboard, you have successfully removed the motherboard from the phone.
  11. LG Xenon Microphone Replacement, Microphone: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Microphone Replacement, Microphone: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The microphone is located on the bottom corner of the motherboard.
    • Take caution when repairing the microphone to not damage the motherboard.
Katy Conlin
crwdns2935283:004/17/12crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-41, Regan Spring 2012 crwdns2935289:0Cal Poly, Team 9-41, Regan Spring 2012crwdne2935289:0
CPSU-REGAN-S12S9G41
crwdns2935297:019crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,112
