LG Xenon Front Case/Screen Replacement
crwdns2869540:0crwdne2869540:0: 1.8K
2
14
82
1,769
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:09crwdne2931287:0
If you have broken or scratched your screen you may want to replace it with a new one.
    1. LG Xenon Front Case/Screen Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the phone so the back side is face up.
    2. LG Xenon Front Case/Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Front Case/Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your thumb to press on the small ridge at the bottom of the phone, then push upward to slide off the back casing.
    1. LG Xenon Front Case/Screen Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Front Case/Screen Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
    1. LG Xenon Front Case/Screen Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Front Case/Screen Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
    2. LG Xenon Front Case/Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push a spudger or small tool under the inner edge of the back panel and gently pry upward to separate it from the main body.
    3. LG Xenon Front Case/Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Front Case/Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pop off the camera, lock, and volume buttons from the side of the phone using tweezers.
    4. LG Xenon Front Case/Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Front Case/Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the Phillips #00 screwdriver to remove the two 3mm screws, which secure the motherboard.
    5. LG Xenon Front Case/Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Front Case/Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully lift and remove the motherboard from the main body.
      • The connector cable will still be attached to the motherboard. Any damage to the connector cable may permanently disable the phone.
    6. LG Xenon Front Case/Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Front Case/Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully unclip the metal tab to separate the connector cable from the motherboard.
    7. LG Xenon Front Case/Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Front Case/Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the connector cable is detached from the motherboard, you have successfully removed the motherboard from the phone.
    1. LG Xenon Front Case/Screen Replacement, Keyboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the motherboard over and carefully remove the keypad from the motherboard.
      • The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
    1. LG Xenon Front Case/Screen Replacement, LCD: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After removing the motherboard and keyboard, unscrew eight 1.6mm Phillips #00 screws in the middle of the phone.
    2. LG Xenon Front Case/Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove slider piece.
      • Pay close attention that you don’t lose the spring.
      • Carefully remove the spring.
    3. LG Xenon Front Case/Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Front Case/Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove six 2.25mm Phillips #00 screws along the outside of the case.
    4. LG Xenon Front Case/Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Front Case/Screen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the plastic opening tool, carefully open and remove the case. Slide the tool along the edge and pry upwards to open.
    5. LG Xenon Front Case/Screen Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the black electrical tape holding the LCD to the screen.
    6. LG Xenon Front Case/Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Un-clasp the small tab in the top right corner.
    7. LG Xenon Front Case/Screen Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Xenon Front Case/Screen Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Xenon Front Case/Screen Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unhook the LCD from tabs on the bottom using the plastic opening tool.
      • Remove the LCD. Be careful, the LCD screen is fragile.
    1. LG Xenon Front Case/Screen Replacement, Front Case/Screen: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Xenon Front Case/Screen Replacement, Front Case/Screen: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once you have removed the LCD, the front case/screen will be left.
      • If necessary, you may remove the call/mute/hang up button.
Micaela Saqui
crwdns2935283:004/19/12crwdne2935283:0
78 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-41, Regan Spring 2012 crwdns2935289:0Cal Poly, Team 9-41, Regan Spring 2012crwdne2935289:0
CPSU-REGAN-S12S9G41
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 82
crwdns2959996:0crwdne2959996:0 1,769
