LG X Power Charging Port Replacement
  1. LG X Power Charging Port Replacement, LG X Power Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG X Power Charging Port Replacement, LG X Power Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG X Power Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG X Power Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
    Don't forget to take out SIM/Micro SD Card tray out before this step.
    James Ford - crwdns2934203:0crwdne2934203:0
  4. LG X Power Charging Port Replacement, Charging Port: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG X Power Charging Port Replacement, Charging Port: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG X Power Charging Port Replacement, Charging Port: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  5. LG X Power Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  6. LG X Power Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  7. LG X Power Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the MicroUSB charging port from the motherboard.
    • If you need help soldering, follow this guide.
crwdns2935229:05crwdne2935229:0
Chad Sears
crwdns2935283:002/14/18crwdne2935283:0
1,200 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S3-G6, Nance Spring 2018 crwdns2935289:0USF Tampa, Team S3-G6, Nance Spring 2018crwdne2935289:0
USFT-NANCE-S18S3G6
Where can i get the charging port part? There are so many different usb female ports.
Wayne Newell - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,114
