LG Watch Urbane Screen Replacement
  1. LG Watch Urbane Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Watch Urbane Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Watch Urbane Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Watch Urbane Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Watch Urbane Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
    Use color markup to note where the pins are.
    Great job of suggesting the magnetic mat!
    Patty Remmell - crwdns2934203:0crwdne2934203:0
    We did use a color markup!
    Rey Diaz -
  4. LG Watch Urbane Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Watch Urbane Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Watch Urbane Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
    when You put a new battery the back cover will not stay in place without glue.
    can you suggest a specific type of glue to be used?
    Maurizio Gaiani - crwdns2934203:0crwdne2934203:0
  5. LG Watch Urbane Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Watch Urbane Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    $19.95
    • Now that you have removed the motherboard and battery, it is time to remove the dock connector.
    • Using a PH000 screwdriver, remove the two screws in order to release the dock connector from the watch.
    • Do not lose the two screws! Keep them somewhere you will remember! A magnetic mat can help with this. iFixit Magnetic Mat
  6. LG Watch Urbane Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Watch Urbane Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screws are removed, the dock connector is free to be moved.
    • Gently lift the dock connector away from the frame and you will now be able to see the screen.
    • The watch's screen is stuck to the back of the glass with an adhesive so be tedious when pulling it off.
Luis Guinand
crwdns2935283:008/31/15crwdne2935283:0
151 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Remmell Fall 2015 crwdns2935289:0USF Tampa, Team 1-4, Remmell Fall 2015crwdne2935289:0
USFT-REMMELL-F15S1G4
where i can find watch urbane display ?
melancholie - crwdns2934203:0crwdne2934203:0
Does anyone know where to buy the display?
James Elmore - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 2,488
