LG Watch Urbane Battery Replacement
  1. LG Watch Urbane Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Watch Urbane Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Watch Urbane Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Watch Urbane Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Watch Urbane Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
    Use color markup to note where the pins are.
    Great job of suggesting the magnetic mat!
    Patty Remmell - crwdns2934203:0crwdne2934203:0
    We did use a color markup!
    Rey Diaz -
  4. LG Watch Urbane Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Watch Urbane Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Watch Urbane Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
    when You put a new battery the back cover will not stay in place without glue.
    can you suggest a specific type of glue to be used?
    Maurizio Gaiani - crwdns2934203:0crwdne2934203:0
crwdns2935229:019crwdne2935229:0
Rey Diaz
crwdns2935283:008/31/15crwdne2935283:0
720 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Remmell Fall 2015 crwdns2935289:0USF Tampa, Team 1-4, Remmell Fall 2015crwdne2935289:0
USFT-REMMELL-F15S1G4
crwdns2947412:012crwdne2947412:0
Where do I find a replacement battery?
nickpfau - crwdns2934203:0crwdne2934203:0
Found mine on ebay. Search for BL-S3 battery.
Atreidae -
The reassembly requires gluing the back together. How do you get the glue?
jiteshshahin - crwdns2934203:0crwdne2934203:0
There is glue around cover. I suppose when closing we should add glue to be waterproof again? Nothing about it in the guide, beside that ok.
Imx - crwdns2934203:0crwdne2934203:0
Pro tip : There are three plastic tags on the rear cover that catch on the frame of the watch to hold the rear in place. If the rear cover keeps falling off after this fix then heat the tags with a hot air blower (hair dryer) until they soften. Then carefully bend the tags outwards slightly and allow to cool. The tags should now catch on the watch frame as intended. Good luck!
Walter ZAMBOTTI - crwdns2934203:0crwdne2934203:0
Great instruction. Happy to find it.
Peter Gamma - crwdns2934203:0crwdne2934203:0
The guide seems to be missing one really important step! When opening the case, you will break the adhesive used to seal the watch in place. You will need new adhesive to reattach the case back to the watch. I tried using an adhesive tape for cell phones from Amazon and had trouble getting it to sit correctly. This step is critical and the case back needs to sit in just right, otherwise the new battery will not charge!
Jeff Dell - crwdns2934203:0crwdne2934203:0
Correct. I have same problem
Florian Pavel -
Great instruction. Important to know if this “old” watch can be used for Linux Asteroid OS:
https://petergamma.org/page-2/
Great guide! Thanks for the help, it took me literally 10 minutes and went without a hitch. Saved me a couple hundred bucks for a new watch!! Respect...
Leo Brereton - crwdns2934203:0crwdne2934203:0
I am in India.. I have same issue.. Is there any help which can be offered in India?
sunny Singh - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 15,821
