LG VX8700 Camera Replacement
  1. LG VX8700 Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG VX8700 Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
  2. LG VX8700 Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG VX8700 Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
  3. LG VX8700 Camera Replacement, Front Bezel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn your phone around and open the flip phone. The screen is now facing you.
    • Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
    • Remove the two grey screw-covers.
  4. LG VX8700 Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG VX8700 Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the ejection tab at the top to remove the screen.
    • There is a gap between the case and the screen near the ear piece.
    • Insert the plastic opening tool in the gap and pry up the screen.
    • The plastic screen cover is glued onto the phone. It may be difficult to pry off.
  5. LG VX8700 Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
  6. LG VX8700 Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG VX8700 Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn your phone around. The battery side will be facing you.
    • Insert the plastic opening tool into the groove to remove the top cover of the phone.
    • Carefully open the cover.
  7. LG VX8700 Camera Replacement, Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now we have the LCD outer case off. The LCD display can be seen on the left, the camera on the right.
    • Place the phone assembly down, it is not needed anymore.
  8. LG VX8700 Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the camera the ribbon connector should be removed.
    • This ribbon connector is glued to the case, using the plastic opening tool pry the connector off.
  9. LG VX8700 Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The camera should come loose after the connector is pried off.
    • Take the new camera and apply a small square of double sided tape to the new ribbon connector.
Andrew
crwdns2935283:001/20/12crwdne2935283:0
7 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-16, Maness Winter 2012 crwdns2935289:0Cal Poly, Team 8-16, Maness Winter 2012crwdne2935289:0
CPSU-MANESS-W12S8G16
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 722
