Replacing your old or damaged battery with a new one will increase the life efficiency of the device.
Power off the device by holding down the power button.
Remove the battery cover by pushing down on the solid lines at the top of the cover. Then simply slide the cover down till it is completely removed.
Place your finger into the semicircle gap at the top of the battery, then push down and pull so the battery pops out.
Wipe down the battery compartment to remove any debris or battery acid. Avoid contact with battery acid as it can damage your eyes or skin.
Insert the new Lithium Ion 3.7V 1100mAh battery into the compartment.
After you finish replacing the battery make sure you put the battery cover back on and you will be all set.
