Sat on your phone and cracked the outer screen? Then here is the guide on how to replace it.
NOTE: Replacing the outer screen requires replacing the entire outer casing.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using a pair of tweezers, remove the rubber screw covers located at each corner of the main screen.
Turn the screwdriver counterclockwise to unscrew the screws located under the recently removed rubber plugs.
Using the "iPod Opening Tool", separate the faceplate from the front of the phone.
Align the new faceplate in the place of the previously cracked faceplate, and press the new faceplate onto the phone.
My phone turns on but the screen is black I think because one side of the phone the is broken where you flip it open it opens but you just can't see the screen
