This repair guide provides step-by-step instructions for safely removing the battery from the LG VX6000.
Locate the dark gray tab on the back of the phone.
Push the tab towards the top of the phone to release the battery.
Lift and rotate the battery away from the bottom edge.
Remove the battery.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Carefully use tweezers to remove the two rubber cushions located at the top of the phone.
Use a Phillips #00 screwdriver to remove the six screws highlighted on the back of the phone.
Carefully remove the back of the phone with your fingernails or tweezers.
Carefully peel away the adhesive tab.
Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
Carefully pry the connector away from the motherboard to remove it from the phone.
Gently lift the corner of the motherboard away from the casing.
Peel the keypad off the casing.
Swap out the old keypad for a new one.
