LG VX5600 Plastic Screen Protector Replacement
  1. LG VX5600 Plastic Screen Protector Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG VX5600 Plastic Screen Protector Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
    • Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
  2. LG VX5600 Plastic Screen Protector Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG VX5600 Plastic Screen Protector Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your finger into the small indentation above the battery.
    • Push down on the battery and pull it away from the phone; it will pop out.
  3. LG VX5600 Plastic Screen Protector Replacement, Plastic Screen Protector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to remove the two rubber covers found at the left and right corners below the inside screen.
  4. LG VX5600 Plastic Screen Protector Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the phone and rotate it 90 degrees counterclockwise for a better grip.
    • Unscrew the two 3.0-mm Phillips #000 screws, found under the rubber covers at the bottom left and right corners.
    • Some of the pictures show the bottom of the phone disassembled. It is unneccessary to disassemble the bottom of the phone for this guide.
  5. LG VX5600 Plastic Screen Protector Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG VX5600 Plastic Screen Protector Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the opened phone upright.
    • Use the spudger to pry around the edges of the phone and detach the tabs.
    • Make sure all the tabs around the grey cover are detached. They are located on the top and on both sides of the screen.
  6. LG VX5600 Plastic Screen Protector Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your finger to lift up the grey plastic cover.
    • Use the tweezers to grasp the plastic screen, and pull the plastic screen protector up and out of the phone.
    • The plastic screen protector is adhered with glue to the back of the phone, so a little force is required to remove it.
Irena Tran
crwdns2935283:006/04/13crwdne2935283:0
435 crwdns2915208:0crwdne2915208:0
University of Kentucky Louisville, Team 1-5, Chamberlain Spring 2013 crwdns2935289:0University of Kentucky Louisville, Team 1-5, Chamberlain Spring 2013crwdne2935289:0
LOUISVILLE-CHAMBERLAIN-S13S1G5
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 511
