Remove the back cover
Remove the battery , SIM card, and SD card
Unscrew the 8 screws using a Phillips (PH#00) screwdriver
Using a plastic opening tool , once again pry up on the edges of the plastic back cover.
Gently disconect the screen cable using a spudger.
Using the spudger, pry the motherboard away from the screen assembly.
Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
Continue to heat and separate until the screen comes completely apart from the rest of the phone using plastic tools
crwdns2935229:08crwdne2935229:0
Pls help how can I fix lg-k120e screen
