To reach the inner workings of your device, you’ll need to remove the rear glass. In addition, if the rear glass of your phone is cracked, use this guide to remove the rear glass.
Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
Allow to sit for 1-2 minutes to heat up the adhesive.
Insert an Opening Tool into the seam between the rear glass and side of the phone.
Pry the glass off just enough to insert an Opening Pick.
Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
