This guide will teach you how to remove the battery from the phone. This will require you to use the plastic opening tool to loosen the back cover of the phone, remove the back cover with your hands, and then remove the battery with the plastic opening tool.
Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
Use your hand to pull the plastic cover completely off of the phone.
Insert the plastic opening tool into the wedge near the bottom of the battery.
Lift the battery out.
