This guide will assist in successfully replacing the LG Tribute touchscreen.
Use the plastic opening tool to pry off the back cover.
Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
Use a plastic opening tool to loosen the tabs around the edge of the phone.
Use a plastic opening tool to disconnect the touchscreen from the motherboard.
Use a thin piece of plastic to carefully peel the frame away from the touchscreen glass.
When the frame is completely free, remove all of the glue.
crwdns2935229:012crwdne2935229:0
thank you for all ypu work at web site
Can you peel away lens without taking apart ?
Must I remove the motherboard to replace the front cover with the glass?
I messed up the speaker is there a way to replace or fix it
