LG Tribute HD Display Replacement
  1. LG Tribute HD Display Replacement, Battery and SD Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Tribute HD Display Replacement, Battery and SD Card: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. LG Tribute HD Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Tribute HD Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. LG Tribute HD Display Replacement, Flex Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Tribute HD Display Replacement, Flex Cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute HD Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Tribute HD Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Tribute HD Display Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, remove the antenna extender from the bottom.
  5. LG Tribute HD Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Tribute HD Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, remove the mid-frame.
  6. LG Tribute HD Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Tribute HD Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Tribute HD Display Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard.
    • Remove the cameras from the phone.
  7. LG Tribute HD Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Tribute HD Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Tribute HD Display Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, pry up the front facing speaker and remove it from the phone.
  8. LG Tribute HD Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the LCD from the motherboard with a plastic opening tool.
  9. LG Tribute HD Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Tribute HD Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry up the motherboard form the display housing.
    • Remove the motherboard from the phone.
  10. LG Tribute HD Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Tribute HD Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the flex cables from the phone.
Aalia Mohammed
crwdns2935283:002/14/18crwdne2935283:0
451 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G3, Nance Spring 2018 crwdns2935289:0USF Tampa, Team S1-G3, Nance Spring 2018crwdne2935289:0
USFT-NANCE-S18S1G3
crwdns2947412:05crwdne2947412:0
Just a note that the flex cables are stuck pretty well to the case. I didn’t rip them but I used a little heat from a hair dryer to soften the glue a bit.
christophergosnell - crwdns2934203:0crwdne2934203:0
I somewhat agree with christophergosnell on this one but I did manage to lift up the ribbon cables using both my fingernails and a small, then, flat head screwdriver at just the right points. there is also a ribbon cable near the bottom of the phone that I had to transplant that is shown but you don’t include a picture of you even attempting to remove it. I didn’t pay attention what it connected to but I just made sure it went in the same spot on the new screen assembly. Other then that a pretty decent guide.
Robert Surles - crwdns2934203:0crwdne2934203:0
Many thanks to the previous comments! The guide is very helpful but could use more detail. I missed the ribbon at the bottom and couldn’t figure out why my speaker wasn’t working. I spent two hours taking the speaker in and out and re-bending the contacts to improve the connection until I checked the comments here and noticed the other ribbon. It was hard to get off so I used a heat gun on low just long enough to soften the glue and then I was finally able to get it off. This solved the speaker problem and all is working well.
James Stephens - crwdns2934203:0crwdne2934203:0
I also used a blow dryer for heat , and small jewellers screwdriver to transfer the ribbons. I also used a magnifying glass
dartswinger70 - crwdns2934203:0crwdne2934203:0
I have reassembled my phone, and it works! Success!. Yes, the disassembly was going smooth, until the ribbon transfer. That's when I stopped, read the comments about using a hair dryer for heat etc. It also helps to have the tools shown in the pic, or very small jewellers screwdriver set like in eyeglasses repair kits.
crwdns2942667:0crwdne2942667:0 3,128
