Before we begin disassembling your LG device, make sure your phone is turned off, make sure you have .the back cover and the battery detached to properly access the sim card board.
Pry open the back cover by using a fingernail or a plastic opening tool.
Remove the battery from the phone.
Remove the three Philips #00 screws from the bottom of the phone.
Two 5.5 mm screws
One 4 mm screw
Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
Power button
Volume button
3D camera button
Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
USB Cover
HDMI Cover
Remove the six Phillips #00 screws within the mid-cover bezel.
Utilize a spudger or plastic opening tool and gently disconnect the ribbon cable that is attached to the black micro-SIM card board.
Carefully pry the board up to detach it from its place in the phone.
Make sure to pry off the small tab connected to the camera unit as well.
