Many people enjoy their phones by texting, calling, browsing, gaming, etc. After a while you may notice that your button pad is not registering as well or in some cases at all. Instead of spending the money to purchase a new phone in its entirety, this easy to follow guide will take you step by step in replacing your LG Thrill 4G phone buttons. Only two tools will be needed for this replacement which are an iFixit opening tool, as well as a Phillips #00 screwdriver. Save money now and use this guide to get your phone buttons back in working condition!
Pry open the back cover by using a fingernail or a plastic opening tool.
Remove the battery from the phone.
Remove the three Philips #00 screws from the bottom of the phone.
Two 5.5 mm screws
One 4 mm screw
Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
Power button
Volume button
3D camera button
Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
USB Cover
HDMI Cover
Remove the six Phillips #00 screws within the mid-cover bezel.
