LG TV 49SJ8000 - WiFi module disassembly
  1. LG TV 49SJ8000 - WiFi module disassembly, LG TV 49SJ8000 - WiFi module disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the display on a soft surface in order to help prevent scratches and/or breaking the display.
    • Remove the 4 Phillips screws that hold the stand in place (if installed).
    • Remove all screws from the rear panel.
    • There are two screws near to the input and output connectors.
    • On the lower part of the TV (next to the speakers) there are two additional screws that need to be removed.
  2. LG TV 49SJ8000 - WiFi module disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the panel removed, it's possible to visualize the boards and its connections.
    • To the left, there is the power supply, which supplies power to the TV.
    • To the right, there is the logic board.
    • On the lower section you can locate both speakers.
    • Between both speakers you can find the Wi-Fi and Bluetooth module.
  3. LG TV 49SJ8000 - WiFi module disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG TV 49SJ8000 - WiFi module disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the Wi-Fi and Bluetooth module, there is only one screw holding the entirety of the structure.
  4. LG TV 49SJ8000 - WiFi module disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG TV 49SJ8000 - WiFi module disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wi-Fi module removed.
    • If your TV shows the message Device Connected/Device Disconnected, Wi-Fi not working or Magic remote not working, it's possible that there is a bad connection on the module.
    • Remove the flex cables carefully and install them once again.
    • In order to remove the flex cable, there is a little tab that needs to be lifted.
To reassemble your device, follow this instructions in inverse order.
crwdns2935229:08crwdne2935229:0
crwdns2934873:0crwdne2934873:0
pt en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Diogo Cordova
crwdns2935283:004/29/12crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
Excelente dica e tutorial! Executei os passos aqui e minha TV voltou a funcionar a conexão de Internet via wifi. Eu usava somente o cabo. O controle magic e os app não apresentam mais travamentos.
Edgar Conrado Pereira - crwdns2934203:0crwdne2934203:0
Obrigado. O chato é que normalmente o problema volta após algum tempo. A solução definitiva por aqui foi deixar sem o módulo, abandonado o uso do Wi-Fi e sem o controle Magic.
Diogo Cordova -
Excellent and works well !! Thank you and I approve it works for SK8100PLA
AAGAYER - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 86
crwdns2936753:030crwdne2936753:0 408
crwdns2942667:0crwdne2942667:0 14,480
