Is your phone not charging properly? Consider using and following the directions on this guide to replace the battery in your device.
Flip the phone over so the back side is facing you.
Use a prying tool or a flat head screwdriver to pry the back cover from the device.
Set back panel aside for later use or to replace.
Use your finger to pull out battery from the bottom of the device.
