LG Spectrum Motherboard Replacement
crwdns2869540:0crwdne2869540:0: 1243
7
24
85
1,243
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
If you are having issues with your motherboard, such as the blue screen of death, constant errors, or crashes you may need to replace the motherboard. This guide will take you through the necessary steps to replace the Motherboard.
    1. LG Spectrum Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Spectrum Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
    2. LG Spectrum Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
    1. LG Spectrum Motherboard Replacement, Sim/SD Port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Spectrum Motherboard Replacement, Sim/SD Port: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
      • Use the magnetic mat to keep the screws in one place.
    2. LG Spectrum Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
    3. LG Spectrum Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
    4. LG Spectrum Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hook the plastic opening tool underneath the plate and gently lift it up.
    5. LG Spectrum Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
    1. LG Spectrum Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Spectrum Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the plastic opening tool to lift up the connector that holds the camera to the board.
    2. LG Spectrum Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the camera gently out of its housing in the motherboard with your fingers.
    3. LG Spectrum Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Spectrum Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the plastic opening tool, gently pry up the audio port connector.
    4. LG Spectrum Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the audio port from the motherboard with either your hand or the plastic opening tool.
    5. LG Spectrum Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Spectrum Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Detach the two cable connector wires from the motherboard with the plastic opening tool.
      • Detach the remaining five connectors from the phone with the plastic opening tool.
    6. LG Spectrum Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Spectrum Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Hook the plastic opening tool underneath the motherboard and firmly lift it out of the phone casing.
Aiman Sallam
crwdns2935283:002/10/16crwdne2935283:0
506 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 1-4, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S1G4
crwdns2936753:030crwdne2936753:0 85
crwdns2959996:0crwdne2959996:0 1,243
