Use the small crease to prop open the back casing.
Find the slot at the bottom of the battery. Use a fingernail or opening tool to pry out the battery.
Use your thumb to gently remove the battery.
Click this button to remove the backplate
Insert your backstick and remove the battery. Alternative tool your nails or something plastic.
replace the battery with new one and follow steps backwards.
