If your battery isn’t properly charging or fails to power your device, you should consider replacing the battery. A battery replacement is a fairly simple process for the LG Rumor 2.
Slide up on the back panel and remove it from the device.
Push down on the battery and pull it out from the notch.
Remove the battery from the device.
